I need to replace the tach drive that bolts into the water pump. I have found a source for the pinion gear and associated timing gear. But after inspection of my present tach drive, I fear that the shaft in the tach drive body is so wobbly I am afraid that it will ruin the new pinion. Unfortunately, I may need to rebuild the entire engine in association with replacement of the pinion and tach drive. Thanks. CK
