I had mentioned this in Chris' facelift thread and decided to post it in case anyone else is experiencing rattling noises with the sunroof in the vent position. The source of the rattle is most likely the springs that hold the headliner vent panel to the metal outer panel. I originally solved it by putting a strip of Gorilla tape on the metal tab.
That was always meant to be a temporary fix, although it seemed to work fine for several months, so as I was taking the pictures today I decided to go ahead and apply my permanent fix which is nothing more than a couple of short lengths of shrink tube.
Pictures should tell the tale.
Most of the time my sunroof does not open but when I hear it rattling as I drive down the road that is a good indication it will open, most of the time.
Mark
Bump up to see how to unlock/unhook rear springs of inner sunroof panel from upper metal panel.
