My sunroof and rear power windows have always worked on and off. You'll hit a bump and then the sunroof wont close randomly, or it works in the morning while cooler outside - stuff like that. Tonight I got finally got angry and kicked the fuse box hard while holding the sunroof button down, and I got life out of those devices - temporarily.
Clearly there is a connection issue in the fusebox, or connectors to the roof.
I pulled the fusebox out and pulled connector 'J', which is common to the rear windows and sunroof. connection seems fine there. The wire then disappears into the wiring abyss behind.
looking at the wiring diagrams, it seems connectors 'G134' - left front pillar connector and 'G112d' - connector d for roof wiring are also common between devices.
To close the windows, I usually put a jumper wire between the power of the front window switch to the sunroof power feed, and both the sunroof and rear windows work perfect, but its not a great fix.
anybody have any ideas where these 'to roof' connectors are? when I look above the fusebox, there is a whole bunch of connectors. Is this it or are there more even deeper?
getting stumped here...I dont want to take the dash top off AGAIN!
