My Alfa survived the great Dallas hail storm last month, but now I've got to get it inspected this month, and wouldn't you know it the driver side seatbelt is stuck only part way out.
I've have seen some posts from those who have fixed the problem in the past, and it seems like I should be able to fix it (unstick, clean and lube).
My question is, when they talk of "pulling back" the door opening seals, I assume they mean the black rubber seals.
I can't figure out a how a seal that you can just pull out could possibly hold the b-pillar, but I guess they do.
Mine are in great condition (the whole car is), and I fear tearing them and not being able to get replacements.
I would have thought that you could simply remove the B-pillar and not touch the seals but apparently not.
Do the seals really just pull out, without tearing?
When done, do I just push them back in with some type of edge?
No glue required?
I've damaged more stuff trying to figure out what to do, and can't afford to mess this up, so any advice will be greatly appreciated.
Same goes for any other advice on the belts/procedure.
Also, has anyone ever replaced the Alfa belts with another brand?
I was in a 2003 Honda Pilot this weekend and the passenger belts were similar (but slightly bigger fastener).
If it's possible and you can't get Alfa belts, it would seem that some other belt could be substituted if it fits under the b-pillar and you can attach it.
Thanks in advance for any advice.
No glue required?
