I'm looking for the following items to wrap up (hopefully) the bits missing from my engine.
105.02.08.131.01 Strut to support the intake plenum cover.
(1) Wing nut that secures the top of the plenum cover to the plenum that's attached to the carbs. I would have thought this would be an easy find, but it's a fine thread, which I cannot find.
Thanks in advance.
The support is thin wall tubing with the ends smashed together and bolt holes drilled. It has a slight angle to it also. In a pinch you can make one until you find the proper one. The wing nut is a 3 wing design, not the usual 2 wing.
Cheers, Jon
" The wing nut is a 3 wing design, not the usual 2 wing.
Cheers, Jon "
You may be thinking of the wing nut holding the air filter lid on. It is a 3 wing type.
Plenum cover nut has 2 wings.
Check the metric section at Ace Hardware.....
I may have the wing nut?? Bought it thinking it was for a Montreal, but it's different. Can anyone POST a picture of one so I can verify this.
Discussion Starter · #7 ·
Wing Nut
Attached is a photo of the wing nut (2 wings). The deal with these is they're a larger wing nut with a fine thread. Typical hardware stores have the big wing nuts, but not with fine threads. Let me know if you have one or two. Thanks!
