Just about any 70s Spider you see has a warped glove box door, mine included. I suppose this is caused by heat.
My glovebox door is made of a metal pan with the vinyl covering, just like the dashboard. At first I was hesitant to try and bend it back and thought of heating it to make it more pliable, but decided against that thinking it may cause the vinyl to separate. I tried bending the top edge gently, but that had no affect.
What DID work is to remove the inside plastic trim facing and metal piano hinge, then grip the door and put a steady, incremental diagonal pressure at the point shown in the picture below. It came out almost perfectly straight and much better than I thought possible.
So, fellow Alfisti, take it for what it's worth. You mileage may vary . . . .
