1 - 10 of 10 Posts
Hi all,
I'm redoing my exhaust and was planning on putting a stinger from Centerline on it. Well, Centerline is out of stock and doesn't know when they will get more. Does any other supplier carry these? Any alternative suggestions?
Thanks!
Bill
easy to make the part in the rear of the axle. local shop should put one togeather for less than 100.00
Centerline actually has stock, but I discovered for them that the latest batch is about 1" too long from the bend over the axle to the connection flange. Until they get corrected stock, they're off the market. It's a very nice piece, made in Italy, finished like an Ansa and would be worth the wait in my opinion. They've been great to work with on this, no complaints here. IAP has them in stainless for over $100 more, but I'd wait.
I have an Ansa dual tip resonator on my 83. Simply plan to have my muffler shop cut out the muffler behind the cat, and weld in a segment of pipe. If yoo loud, muffler can always be re-welded in.
Why not try that first and see how it sounds? no one is looking under to see the Ansa style pipe itself. :)
Take it to a good exhaust specialist and have them make it from scratch. Should be pretty cheap......definitely cheaper than buying an ANsa and getting it cut up.
Why, yes I do. I had it on for 3 days and took it off to go another way. It has been setting in my (dry) garage getting dusty.
Hopefully Joe Cab is following this thread and he will let us know when he has them back in stock.
Did you notice this a few posts down?
"Need to get my Alfa sounding more like an Alfa. :) "
1 - 10 of 10 Posts
