If I had known APE had a later model ignition switch, I may have given that some consideration, but at almost twice the price, I do not know. My mechanic was able to get the older model ignition switch to work and I like no longer having to mess with the red key release switch. I have the lock cylinders for the two doors, the trunk and the glove box and my mechanic says it will cost about $200 to $300 to switch those out so that everything works off of one key set. I will probably have that done, but will defer it for a while as I have spent about $1,200 or more on replacing worn out items including: new tires, new radiator, new ignition switch, a fixed climate control console, and had all four rims renovated so that they look good as new. Hopefully this will do it for a while.
Good luck with the sticking key issue, it may be just something simple. I figured my failing switch was just isolated to just my car. It sounds like other owners of the 94 and 95 models may be having similar issues.
Jeff
Dallas, Texas
