1 - 20 of 49 Posts
***NOTE: This procedure has now been edited to include corrections/suggestions from the thread below***
Hi All-
I had trouble finding a "best practices" post for a routine maintenance head re-torque all in one place, so I have taken a shot at creating one below. Comments and corrections appreciated.
How to Re-Torque a Head as Part of Routine Maintenance
0. → Make sure you have an accurate torque wrench. ←
1. For maintenance, do a “cold re-torque”, meaning the engine is completely cold. While it is called a “cold re-torque” it is actually involves a warm re-torque as the last step.
2. Remove radiator cap, then squeeze the top radiator hose down with your hand, then reattach the radiator cap while still squeezing the hose. This will provide some vacuum, which can help prevent water exiting the stud passage when you loosen the head nuts.
3. Back-off each head nut, one at a time, in sequence according to one of the torque patterns below. Consensus seems to be that any of these patterns is fine, though many prefer either the spiral or “papajam” pattern. Remove each nut and washer. Each nut will be both removed, then re-fitted before moving on the next nut in the sequence. If you remove more than one nut at a time, you will have a lot of coolant seepage.
4. Inspect where the head where the washer makes contact and ensure it is smooth and clean. If not, clean it with a brass/copper brush.
5. Ensure the washer is clean and smooth on both sides. If not, clean it with a brass/copper brush.
6. If nuts don’t remove smoothly, clean threads of stud and nut.
7. Lube (with motor oil) both sides of each washer before re-fitting it on the head. NB: The flat side of the 8 thick washers need to be facing down toward the head. Rounded side goes up. For the 2 thin washers on the center lifting strap, the direction of the washers doesn’t matter.
8. Lube threads of each stud (not inside the nut, but the stud) before re-fitting the nut on the head.
9. Screw the nut down by hand until it reaches the washer. If nut doesn’t re-fit smoothly by hand-tightening, remove again and re-clean threads of stud and nut. If that doesn’t work, then chase nuts with thread tap to clean up the threads.
10. For a maintenance re-torque you can torque to 100% in one pull. But if you decide you prefer to do it in increments and want to be uber-thorough about it, you would torque each nut in 4 stages, performing each torque setting twice:
a. ~30% of the toque spec on the first pass
b. ~60% on second pass
c. ~80% on third pass
d. 100% on fourth pass
11. Repeat above process through each nut according to the pattern sequence diagram above. Remember – one nut at a time!
12. Once all nuts have been re-torqued cold, then drive car until up to full operating temperature for a “warm re-torque” to finish the job. Torque each nut in any of the patterns noted in step 3. Some folks like to vary between one type of torque pattern for the cold part and a different pattern for the warm part of the re-torque. E.g. do spiral for cold part of the re-torque, then papajam pattern for the warm part of the re-torque.
13. OPTIONAL: If there is a coolant or oil leak present at the head that you are trying to remedy via a re-torque, advice is to perform another cold/warm re-torque sequence as per above (i.e. one nut at a time in a spiral pattern), but instead of removing the nuts, just back them off ¼ turn then re-torque to 2 ft/lb above the final torque specs listed below (e.g. if normal spec is 58, then torque to 60.)
Torque specs – final torque pressure by engine displacement. This applies to 105/115/116 Series “street” motors, not race-prepped motors. People like to debate “what is the right torque pressure”, but below is what Alfa spec calls for.
• 1300, 1600: 52 ft/lb
• 1750: 58 ft/lb
• 2000: 65 ft/lb
Hi All-
3. Back-off each head nut, one at a time, in sequence according to the spiral pattern below (see first figure below). Remove each nut and washer. Each nut will be both removed, then re-fitted before moving on the next nut in the sequence. If you remove more than one nut at a time, you will have a lot of coolant seepage.
10. Torque each nut in 4 stages, performing each torque setting twice:
11. Repeat above process through each nut according to the pattern sequence diagram below (first diagram). Remember – one nut at a time!
12. Once all nuts have been removed and re-fitted, let the head sit for a couple of hours to let the gasket "relax" then re-torque again at 100%
13. Once all nuts have been re-torqued cold, then drive car until up to full operating temperature for a “warm re-torque” to finish the job. Torque each nut in either the spiral pattern illustrated in the diagram below (first diagram) or, optionally, in a traditional “criss-cross” pattern noted below (see second figure below). Some folks like to vary between the spiral torque pattern above for the cold part of the re-torque and a “criss-cross” pattern for the warm part of the re-torque.
14. OPTIONAL: If there is a coolant or oil leak present at the head that you are trying to remedy via a re-torque, advice is to perform another cold/warm re-torque sequence as per above (i.e. one nut at a time in a spiral pattern), but instead of removing the nuts, just back them off ¼ turn then re-torque to 2 ft/lb above the final torque specs listed below (e.g. if normal spec is 58, then torque to 60.)
• 1750: 58 ft/lb
• 2000: 65 ft/lb
you overlooked the part about having a headless chicken in the trunk and and making sure you are facing north and standing on one foot while holding the wrench in your left hand only...
why all the mythology ? and whats this about the gasket " relaxing " ? if your gasket is " relaxing " its already scrap.
all al heads are done cold ... always cold... never hot or warm . and the system on this car is the same as every other in the world. 3 stages ... spiral or crisscross depending on who trained you. if its a maint retorque then you crack the nuts loose one at a time noting what it took to release them and then pull it back down at a few lbs more than that number or the spec called for originally which ever is greater because once you release the clamp load on the gasket you need to exceed that when you retighten it to make certain it re compresses and seals...
there is no need at all for any magic process.
This is an urban myth.....
Rebuilt my '64 Spider in 1980 and never retourqued the head. Works fine.
not urban myth at all. if done properly ( torque properly, heat and stress cycle once , full cool and retorque ) the first time it shouldn't need doing again. but having said that, clamp load is a strict function of hardware preload. all materials " cold flow" under stress to some degree. in metallurgical terms its called intermolecular creep. that means you put enough stress on something long enough and it changes dimension. so... over time , if left to their own devices the initial preload will diminish slightly even if the materials are inside their elastic limit. combine that with the fact that the gasket is organic to some degree and compress-able and as the studs are subjected to high cyclic load and heat and all manner of thermal cycles and suddenly the notion of " gee it SHOULD be fine forever " becomes " gee for the sake of 30 minutes , i can be certain its good for another 10 years or so..."
my 79 had 30 k on it when i got it and had been sitting for 25 years . it only needed 35 ft-lbs to release the head nuts and almost a full additional turn to pull them up to 70 . sometimes being sure is better than what the theory says. in my case im sure it saved me a repair.
"in metallurgical terms its called intermolecular creep"
Perhaps my '64 hasn't heard of this.......
Do you have a graph (in feet) of how much creep per year will occur ?
Also, my GTV rebuilt in 1991 and my Super rebuilt in 2010 seem to be functioning fine with a little intermolecular creep.
its a function of the molecular bonds of the various materials as related to stress and temp. very brittle materials like glass are at one extreme of the scale and softer more compliant materials are at the other end. titanium creeps less than , say aluminum ... that sort of thing. in the case of cylinder heads it is far less of an issue than , say , the compress-ability of the gasket and how it will cold flow or even de grade over time depending on what it is made of and what it was subjected to. i don't think anyone is suggesting that retorquing should be on the same schedule as spark plugs... but every 10 or 15 years isn't such a bad idea. feel free to ignore anything you don't understand . if you are happy with and trust your assemblies then you have nothing to concern yourself with in regards to any of this.
My experience is that most head gasket issues are caused by poor workmanship and or materials and all of this retourqing is an attempt to delay the consequences.
well... if thats your experience then stick with what you know and understand.
certainly if a job is done badly for whatever reason then some patchwork later isn't going to be the answer but thats not what anyone is talking about and my car was factory assembled and had lost 1/2 of its preload over time.
being through and meticulous is not the same as trying to make up for what you did wrong in the first place and there is no downside at all to retorquing in exactly the same way as there is nothing wrong with doing a nut and bolt check over any other job you did. anal ? maybe . but no downside at all. some might say it shows genuine care and concern for a job well done.
Richard Jemison
I totally agree.
Not only should the heads be retorqued, but the Factory torque specifications are too low.
I know of NO professional engine builders using less than 10% higher torque specs on Alfa engines.
I use 75 lbft on the 12mm head studs/nuts on the 1750/2000/Montreal.
Low head torque is directly the cause of the Montreal engine`s headgasket issues. In a TSB (01.71.2.1) the torque specs were given as 8.1-8.2 KGM hot.
I used 75 lbft on mine (75 lbft = 10.4 Kgm)
FYI: 1 lbft + 0.138254954 kilograms m
Excellent writeup, Scott!
I would however add to #7 that the flat side of the 8 thick washers need to be facing down, toward the head. Rounded side goes up. Doesn't matter for the 2 thin washers on the center lifting strap though.
#10. IMO, there's no need to do incremental pulls for a cold retorque. One pull to the final value is all that's needed (assuming sufficient swinging room).
Well, there's no shortage of threads on this topic. Everything I wrote above is just a collection from a variety of threads on this topic, mostly coming from THIS THREAD and its many offspring.
This question of this thread isn't "do you think re-torquing is a good idea". The question of the thread is "is this a good procedure if you are doing a re-torque".
Why the mythology? Because Alfas have a very long history of head gasket issues and conflicting/changing advice from Alfa itself (not to mention various non-Alfa manuals) regarding how often to re-torque, under what conditions and in what nut order. Given that, I am just trying to collect best practices provided across many threads over the years in one place in the event it might be helpful to someone and someone might have some updates or corrections to it.
That said - I personally don't think the "let the head gasket relax" matters, but guess it couldn't hurt.
Discussion Starter #12
Ah - thanks Jim. It's mostly advice you have written before across many threads just put all in one place. Thanks for the add'l info and with any other that comes in, I'll update the final flow.
At least on the V6 I've fixed oil leaks twice by retorquing. YMMV.
I'm with Jim on the four-stage torquing. You can just torque each nut once smoothly up to the desired value and call it good. Probably a good idea to make sure you're using an accurate torque wrench too.
Discussion Starter #14
Ah - good point. It's always worth reminding about the accuracy of torque wrench.
If I can add one more thing I learned from Papajam was the sequence. I like it because last 2 nuts to be torqued are at the rear where most of the leaks are.
Thanks for the thread.
Vin
My 30-year experienced Alfa mechanic (theres no substitute for having worked on so many cars over the years. in LA where there is so many) says that 'loosening' is nuts. he does a cold re-torque for me every two years, and ONLY TIGHTENS to spec.
I should mention that my motronic alfa has 200,000 miles and runs perfectly
on any fastener in any application, automotive or otherwise correct and standard practice is to release the preload and then re-preload. this is to insure that the threaded section is free to rotate without rust or corrosion or any other friction generating circumstance that will cause the torque being applied to be inaccurate. now... if your guy thinks anyone is talking about loosening ALL the head nuts and then retorquing , you have mis informed him and that would be the wrong thing to do. if he is simply cranking on fastners that are already tight and have been that way for any length of time then he is wrong and it doesn't matter how many years he's been doing it... its still wrong. this isn't magic and its not voodoo and it has nothing to do with alfa or ferrari or yugo or mercedes benz. it is standard engineering practice as to how threaded fasteners in ANY application are treated. the ONLY variable is how the factory calls out its torque spec whether done dry or with oil or with moly or any other specific lube whether in lb -st or angular deflection or total stretch... the raw methodology, however, is always the same and anythind done any other way is wrong to some degree. everybody wants to think that everything has to be special or magic or so secret that only the few can know the tricks... and thats nonsense. these are not formula 1 cars and they are not special or different in any meaningful way as to the techniques necessary to work on them properly.
Discussion Starter #19
Have to agree with stevesxm. Having newly adopted "re-torque head" as part of my maintenance routine, I recently had nuts that were corroded on. I could've re-torqued to 100 ft/lbs without any outcome because the corrosion was the resistance, not the actual nut/washer contact with the head. This would be true with any corroded or otherwise binding fastener. You have to level set with a free moving fastener (by loosening it) to assure that your torque measurement is actually the pressure applied from the fastener to the item being torqued.
Discussion Starter #20
Vin - thanks for adding that diagram. I was looking for a source to pull from when writing this, but couldn't find one and didn't want to guess at it. I'll add this in the final write-up. Given that any leaking head I have had also leaks from the rear, I would agree that this one seems to make the most sense. I like the idea of varying the pattern (this one, then spiral, etc.) on an aluminum heads just to ensure even pressure. I can't back that assertion with any metallurgic data, but seems to make logical sense.
1 - 20 of 49 Posts
