The horn assembly has not been available for many years, and they do wear. You simply have to work with what you have, and there really isn't much you can do... so be careful when taking it all apart...
Best regards,
The horn assembly has not been available for many years, and they do wear. You simply have to work with what you have, and there really isn't much you can do... so be careful when taking it all apart...... are there available parts for it, ...?
Do you have any 'friends' who like to play practical jokes? We used to play a joke by hooking up a wire from the brake light switch to the horn. Everytime they'd come to a stop the horn would blow!...it was activating my horn while driving (it was annoying).
Naaah... I`m not even letting my wife to touch my Alfa.. she drove it only once, 5yards on drivewayDo you have any 'friends' who like to play practical jokes? We used to play a joke by hooking up a wire from the brake light switch to the horn. Everytime they'd come to a stop the horn would blow!
It took some people quite a while to make the correlation...
The horn in our '84 started blowing when I let out the clutch. Turns out the wire that comes out the end of the column (under the hood) was too close to the exhaust manifold. The heat burned off the insulation and starting up in first gear (i.e. letting out the clutch) rocked the engine enough to ground the wire against the manifold.
I just took one apart so I could paint it and sit it on a shelf to look at.Posted by he3r0:
but my Question is: is this part easy accessible after pulling the steering wheel out? are there available parts for it, or should I prepare for manufacturing spring or remodeling steering wheel a bit?
Excellent photos, Dana! I'm so glad that they also clearly show the horn assembly, which is one unit you don't want to damage in any way... Very pretty wheel, as well... No wonder you have it "on display".Had a few minutes before doing our Sunday duties.
Here are some photos of my Hellebore taken apart.![]()
Well... part of your response is in wrong threadCouple of things here. Looking at the first picture in the other post, it looks like your spider has a contact sticking out from the hub assembly for the horn. The hellabore wheel pictured has doesn't have a contact ring on the back of it of it to match. We need to see a photo of the back of the wheel that is on your spider that matches the hub/horn interface. The hellabore has the blue wire coming off the center, that wire, on most spiders would plug into the wire coming up the center of the stator tube. Intrinsicly(sp) I don't think there is anything wrong with your hellabore, the three activation arms have different feels to them , that is normal.
Sorry for the confusion, my post was directly in response to the post directly above it, In that post, I used the word "post" when I should have used "thread". Now that that's unclear, I've taken apart a bunch of these wheels (and put them back together), and could be wrong, but my experience is the arms, at least one, always feel loose. Does your wheel have the plastic insulator bushings?Well... part of your response is in wrong threadmy hellebore works (almost) good, in this thread http://www.alfabb.com/bb/forums/showthread.php?t=48548
GraniteAlfa is doing a swap.
as for my horn thingy, I do realize that it may feel a bit, but this one is just very very loose, you would have to feel it since I cant really explain it.
sorry for confusion :0
time to get some beer, I`ve had terrible day![]()
yes, on all of three paddles,Sorry for the confusion, my post was directly in response to the post directly above it, In that post, I used the word "post" when I should have used "thread". Now that that's unclear, I've taken apart a bunch of these wheels (and put them back together), and could be wrong, but my experience is the arms, at least one, always feel loose. Does your wheel have the plastic insulator bushings?
Good luck, you've seen this thread? http://www.alfabb.com/bb/forums/showthread.php?t=23962&highlight=steering+wheel+removalyes, on all of three paddles,
and I even tried to pull steering wheel again today, but I just cant.. have to get a butane for my pencil torch...
That is a great thread, i dont known how did I missed that, Thank You!Good luck, you've seen this thread? http://www.alfabb.com/bb/forums/showthread.php?t=23962&highlight=steering+wheel+removal
I've never had to use heat for this operation, if when tightening the puller seems not to be working, try, with the puller tight, a few hammer blows to the sides of the hub
