Have noticed lately, for the first time, that under power at speed, 4 th gear at ~60-70 mph, the 91S pulls one way with mashed throttle, and steers the other way with foot off gas.
Have jacked up the car and inspected the front and rear suspension, finding that the bushings in the front lower suspension arms look good (new arms installed ~80k miles ago), and there is no play in the steering tie rods (new with the replacement rack installed ~80k miles ago). The rack appears to be firmly mounted with no lateral/vertical movement. New lower outer ball joints. Rack leak stopped with Lucas.
The replacement rear suspension trailing arms were installed ~60k miles ago. Their front bushings look good. The transverse rod bushings, inner and outer, look intact/fine, although I would think that applying engine torque (or not) to the front suspension would not cause a steering problem back there, as they are just along for the ride, ie, no unequal loading from, say, powered axles.
All engine mounts are either good or new, including the dog bone mount. New S clutch installed ~5k miles ago.
S struts rebuilt ~20k miles ago. No unusual motion over bumps. Alignment ok, even tread wear.
So, my feeling is that either the inner tie rods are worn, regardless of not showing any play when the steering is turned, or maybe the left front lower strut bushings are soft since it appears that the diff left side axle gasket is leaking some lube all over that area and that may have softened those arm bushings.
Any other ideas? I suspect what I will do is replace the lower front suspension arms again, and the inner tie rods replaced. Now that Carlo (my trusted mechanic since 1966, loved him like a brother) is no longer with us, alas, bless his soul, who can be recommended do the work for this aged citizen, lol?
