1 - 17 of 17 Posts
Recently I was in the Garage Attic and found several Steering boxes that I thought I might sell. Well I found about 50% of the Burmans with cracks. In the process of sorting these and helping some members with incorrect boxes installed in the Alfas, I found a number of variation amongst my hoard.
Of the Burmans I found 3 shaft lengths that I will call long, medium and short.
I also have an early ZF and another ZF install in my project 1964 Sprint GT.
I will provide Tube length, tube plus to threaded end, Shaft over all, Year/type, key location if possible. Lengths in cm are close to accurate +/- 2 mm
I invite others to add their information or comments.
Discussion Starter · #2 · (Edited)
Burman Long 1970 box Shallow dish wood Hellebore
Tube 64 cm
Tube to threaded end 74 cm
Shaft over all N/A
Year/Type 1970/ GTV
Key position Right side
Wood Tool Flooring Hardwood Office supplies
Wood Gas Metal Font Auto part
Discussion Starter · #3 · (Edited)
Burman Medium Shaft
Tube 63 cm
Tube to threaded end N/A
Shaft over all 84.5 cm
Year/Type 1
Discussion Starter · #4 · (Edited)
Burman Medium 1969 box with lower Boss
Tube 63 cm
Tube to threaded end 72.8 cm
Shaft over all N/A
Year/Type 1969
Gas Door Wood Concrete Tool
Fixture Gas Auto part Metal Nut
Discussion Starter · #5 · (Edited)
Burman Medium 1969 box with lower Boss Giulia Super?
Tube 63 cm
Tube to threaded end 73 cm
Shaft over all N/A
Year/Type 1969/Giulia Super?
Key position left side
Air gun Trigger Wood Shotgun Gas
Gas Font Metal Auto part Machine
NOTES: my 1969 build Giulia Super Biscione came with what appears to be this type of box. What is interesting is that it came with a deep dished plastic rimmed steering wheel but a shallow dished 71 wood Hellebore fit right up. This super may be a transition car as it has floor pedals and fuse box under dash on a welded on bracket.
Discussion Starter · #6 · (Edited)
Burman Short box Measurements from 1970 GTV Shaft, 1971 GTV Shaft, 1975 1600GTj Box
Tube 62 cm
Shaft over all 83.2
Year/Type 1970/ GTV
Key position Left side
Pictured the 1975 box and a 70 shaft
Wood Gas Gun accessory Metal Shotgun
Grey Wood Gas Automotive tire Automotive exterior
Discussion Starter · #7 · (Edited)
ZF box early no provision for key, boss on bottom
Tube 62 cm
Tube to threaded end 71.5
Shaft over all N/A
Year/Type early
Key position None
Downhill ski binding Composite material Asphalt Flooring Tool
Wood Door Metal Composite material Shadow
Metal Wood Auto part Bicycle part Titanium
Photo of 64 Sprint GT installed
Water Gas Concrete Bedrock Automotive tire
Discussion Starter · #8 ·
Burman Medium 1968 box with lower Boss GT junior
Tube 63 cm
Shaft over all N/A
Year/Type 1968 GT junior
Key position None
Wood Door Shotgun Tool Metal
Wall Wood Gas Door Machine
Wood Plumbing fixture Household hardware Gas Plumbing
Discussion Starter · #9 · (Edited)
Burman U-Joint type Box 1974 GTV or Berlina not sure
Tube - n/a
Tube to Threaded end - n/a
Shaft over all to end of u-joint 71 cm
Year/Type 1974 GTV or Berlina
Key position Right
Tool Gas Font Wire Art
Handle Gas Fixture Household hardware Metal
Grey Wood Gas Tints and shades Automotive tire
Reactions: Gordon Raymond
I had NO IDEA Ken. Thanks for posting this. Further, those with cracked housings, all cracked in the same areas? All different types or one more likely to crack than the others?
Discussion Starter · #11 ·
Hi Gordon, I cannot easily draw any conclusions so I will not but do have the impression that the short boxes are more prone. Thanks for your interest.
Ken
Excellent post Ken. Valuable to everyone.
Discussion Starter · #15 · (Edited)
Not sure about the Berlina? I used one of these u-jointed boxes that I removed from a wrecked 1974 2000 Berlina in 1985 and used it on a 2000 GTV.
I used one of the u-joint type on a 1971 FI GTV and had to cut the firewall opening a little for clearance. Did you have to cut??
Moderator
No, and the 2000GTV I installed this on was an early one (3020582). The rubber boot that seals the firewall around the column though is specific GTV vs Berlina and u-jointed vs straight column - I had to be creative to fit a boot. Don't ask the details.
This reminds me that I first installed this u-jointed box on my winter beater, a 1971 1750 Berlina that I later dismantled. It was 100% bolt on.
Discussion Starter · #17 ·
Maybe I cut firewall to fit boot. I don't remember.
K
1 - 17 of 17 Posts
