I am going to replace the driver side steering rack boot on the 164 LS
Do I have to remove the tie rod from the steering arm and what is recommend to do this [pickle fork, vibration with hammer or tie rod pressing tool?] or can I just turn the steering rack rod and back the threads out of the tie rod still attached to the steering arm? Will remember to count how many turns .
I had to cut the tab off the rear gravel shield, it seems the the factory installed the gravel shield first and then the brake and ABS lines.
Frank
'94 164 LS
Frank
'94 164 LS
