I believe that is correct, but you can check if you have a voltmeter with an impedance setting. I believe that the post that gets the smaller red wire(ignition) should have continuity to the post, but if you hook it up using a vise and a battery that will tell you for sure. Don't worry you shouldn't be able to hurt it by hooking it up wrong once for a second, at least I never have.
