I recently replaced my starter for the second time. Before replacing it, the starter would turn but grind (the bell housing had broken). Post replacement the starter will not turn. I believe i have it wired correctly, my dash and fuel pump are both getting power, but the starter will not turn. I notice that a small cylinder (looks like some sort of solenoid) very close to my starter has no wire attached where one definitely could be.I believe this cylinder is my cold start solenoid. If that is the case could that be my problem, and where should I wire it to? If not, do you have any ideas on what my problem could be?
Edit one, I can provide any necessary diagrams if you need help understanding my problem
