Hi there
I have a 1750 Berlina MKII and yesterday I heard a metal noise, I check and the starter motor was almost loose. What I manage to see from the top of the engine bay was one nut missing and the other bolt and nut loose but still there.
I realise there must be another (or two more??) bolt/s in the bottom, question are:
Are there three or four bolts?
Do I have to remove somenthing to get to the bolts adjusted??
I managed to adjust the one that was almost loose, I will have to buy the other nut and I presume the bottom/s bolt/s and nut/s.
It gets to difficult to adjust the nuts from the bottom?
Thanks in advance!!
Diego
From below (underside car) is the best way to access the bottom bolt/nut. That one also attaches the grounding strap to the body
