I have a few broken teeth on ring gear so I plan to replace it as it has broken the cone end of the starter (x2) off. If you have a junk starter I might be able to use the cone half of a Bosch starter. One is a SR484X and the other is Bosch # 0 001 311 110.
130 tooth ring gear and 9 tooth starter gear.
I'd prefer a working starter but, like I said, I might be able to salvage one with the right parts.
Thank you,
Ken
I have my original '74 Spider's working starter and flywheel. Replaced them with a lighter, later starter and flywheel when transmission was rebuilt. Tonight after I get home I can count the teeth on the starter gear and confirm.
Warning these guys are heavy!
I've found RA is very lenient on the cores being returned. Several times in the past I've returned a completely different starter (still a Bosch). Got my credit.
