Friday I started on a new project as there is a couple of race prepped blocks and enough engine components stored in the shop to complete a couple of very high HP / race engines.
I decided this one would probable be built to 11 to 1 CR and have assembled the components and finished one of the race heads using my 13mm intake and 12.8MM lift exhaust cams. The idea being an engine that can be driven on the street using 93 octane ethenol premium or 100 octane unleaded race gas.
At least that`s my direction at this point.
Here`s what has transpired so far;
Block was put through a through chemical and acid cleaning final finish of a new block. That done a steam cleaning was done after the main oil passage line`s restriction was enlarged. At the area of the motor mount it was drilled and opened from about 7mm to a full 3/8" passage. This assures full flow to the rear oiling passages to the crank and to the heads middle and rear cam bearings.
Here`s pics of it on the engine stand:
At that point the main bearings King Black series race bearings were fitted and the balanced crank with the slotted main bearing oil pick up holes to increase oil supply to the mains was installed. The crank is a larger journal "red" marked crank with all main bearing journals measured at 2.3613 (these cranks have main journal specs of 2.3611 to 2.6315. The "plastigage" clearance in the bearings were .0013 -.0015
I haven`t installed the pistons and liners but but they are assembled on Maxeeding rods with King Black race bearings.
More to follow as it progresses.
Rj
Rj
