1 - 2 of 2 Posts
Hi
Has anybody a template or the measurements of the cut out for the pedal box for a RHD.
1613496
Ciao Shane, I suggest that you insert the pedal assembly and then produce the initial slot holes for the pedal arms and then extend the slots to gain the necessary arm movement with minimal clearance as this is open to the outside!
For RHD restorers going through a restomod you’ll also need to consider which pedal arms to utilise as there are varying lengths, obviously they need to configure well with your feet but I went for the long brake and short clutch pedal arms
1 - 2 of 2 Posts
