I have a 1965 Giulia Spider Normale that won't start. I drove it home from an event fine and then it would not start again. Turn the key and nothing. Before I start ripping into it, does anyone have some suggestions to shorten my search?
If your engine was up to temp when you went to restart it, the starter housing has picked up engine heat and is not strong enough to overcome the additional friction within the unit. If you let it cool off for a few hours, it should start on the first try. The solution is to have the starter rebuilt or changed out. Rick
Won't Start
I have a similar problem with an 84 Spyder. It won't even click. All other electricals seem to work and it starts if I pop the clutch.
I was wondering if there's a neutral safety or clutch pedal switch that went out, but I'll start on the wires to ignition/starter.
Tom
Spider won't start
Thanks for all of your advice. I found a poor cable connection that was the culprit. Spider Larry
