G
Guest
·88 spider won't shut off when you turn the key off.
Still runs after disconnecting battery. I believe I must take the dash and column apart to accesss the ignition switch. Somebody apparently tryed to steal this car when it was new. The ignition switch had been replaced as part of that. I suspect that could be the issue? How to get Column apart help would be good too.
Any Ideas? Thanks
Any Ideas? Thanks
