If somebody has a Spider window motor laying around, the style with the flat face mount flange, could you please tell me the distance of the mount holes, center to center? Thanks very much.
Thank you Steve... but what I am after is the distance between mount studs on the motor, not the regulator assembly. I'm sorry if I didn't make that clear. I see here you have the same motor I do, with the external long studs. I am needing the mount hole dimensions on the flange, for the newer style motor, with just a can enclosure. Like this:
ok-- I now see your last photo! That's the measurement I get, also, but I want to use the newer style motor.
