Good question. I might like one to tow a lightweight runabout boat. Would like to hear if others have done the same.
I think the weight towed would be limited by the shock absorber bumper mounts and why would you want to go to the trouble of removing a bumper every tow? I've towed a complete Alfa behind a truck using a tow bar attached to front bumper shocks, but I was nervous all the way. For extremely light towing, they use to make a tow hitch (ball) that clamped on most chrome bumpers of the 60's and 70's, so why not to a 74 spider and leave the bumper on too? Not a lot of engineering involved to adapt one to a older spider bumper. A Series 3 or 4 rubber bumper is another story.There's not much underneath a '74 to bolt a hitch onto. How about removing the bumper and using its mounting points for a custom-made hitch?
By golly, you're right. I never had the back bumpers off the 72, 73 or 74 and just assumed they were collapsible like the front mounts are. Maybe I should have towed the things backwards (not). I'd still use a clamp on ball hitch on the steel bumper, perhaps using a dinged up spare bumper.Pre-'75 Spider's don't have any bumper shocks. There is a rigid tubular mount coming out of the body (one each side), and on the '73 and '74 cars rubber blocks space the bumpers out farther from the body than on the '71 and '72 cars.
My hitch was custom made by a shop in Lexington, KY. (It's about 2 hours away from my wife's hometown in OH. The Spider is with us in NJ right now, but it will spend the winter in OH.) The fellow who did it specializes in fabrication for performance and race cars. I observed that many of the SCCA racers would haul their tires to the autocross in little trailers, so that's what I did. The fabricator had done this many times for a variety of small cars, but not on an Alfa Spider, although he was certainly familiar with our Spiders.Zunige - looks great! Where did you have it installed (I'm in Jersey too) and how did it mount, and what brand is it? Cost? Details please!
Great pics. I wonder how it would mount on my S4? With the rubber bumped shroud in the way.
That was pretty easy, although it did take me some time to do it, but that's probably because I'm beyond meticulous and anal about how things look in the car. If you lift the trunk carpet off the rear driver side area, right in front of the rear light, you can access all the wires. The brake light wire from the driver side of the car feeds the passenger side break light, so there is no need to do anything on the passenger side. The passenger turn signal lead is separate from the driver lead, and it was little trickier to identify, but it also comes from the driver's side of the car, so again no need to do anything on the passenger side. Note that that you do need to use a kit for cars with separate lights for turn signals and brakes. (Inexpensive, even if bought separately and there are versions that have a test module built in.)Also, how did you get the wiring installed?
Given the nature of the Spider body, and the hitch that could be installed, I think that not exceeding a total towing weight of 500 lbs. is a key decision making factor. Hence, you need to determine accurately the weight of the scooter and the trailer. My trailer, which is an inexpensive utility version, with a piece of plywood fitted on top, plus the hooks that I added, weighs 173 lbs.Has anyone here installed a trailer hitch on an Alfa? I have a '74 Spider and would like to be able to attach a low, very light duty motorcycle trailer for Vespa and Lambretta scooters. Any thoughts or recommendations?
