Spider Technical FAQ Digest - Version 2
We have developed a Spider (much of it is also helpful to the GTV) specific FAQ for the Forum. There are many excellent threads that have answered the most common and some not so common problems. Searching the forums can be difficult due to the huge amount of information found. Browsing is still very informative for those new to the BB or to the Spider. All of those that have added to the FAQ have certainly helped many Alfa Spider Owners and maybe some of the other models too!! Keep up the good work.
This is a group effort and if you see a good thread, go ahead and put a link to it in THIS thread by hitting reply and adding it to the end. Don't be shy about adding any items!!! I will add it to the first index page when I do maintenance.
Complete Car - Unit 00
#8 Chassis Stiffener Dicsussion
#21 Emergency Release Cables - Hood & Trunk
#25 Homemade Wind Deflector
#67 Wheel Stud Length
#71 MUST Have Spider Manuals
#73 Spider FAQ (non Alfa BB)
#109 Get your Alfa's History
Engine Main Mechanical - Unit 01
#9 Oil Seperator
#12 Engine Oil Viscosity Debate (Oil Jihad!)
#18 Replace Motor Mounts
#29 VVT Rubber Bushing repair
#40 Plenum Vacuum Fittings
#57 VVT O-Ring
#70 Lower Oil Pan Removal
#84 Series 3 Drive belts
#87 Head Gasket Replacement with Pictures!
#88 Motronic Top Dead Center - TDC
#120 Replace Pistons and Cylinder With Engine in Car
#114 Series 4 Trouble Codes
#129 Retorque Cylinder Head
Fuel System - Unit 04
#2 Fuel Injector Cleaning
#3 Gas Smell in Trunk or Interior/High Pressure in Gas Tank
#4 3 Series Spider L-Jet Diagnostics
#10 Fuel Vapor recovery (Gas Smell in Car)
#14 Resetting EXH Sensor
#39 Thermo Time Switch (TTS) Diagnostics
#42 SPICA Starter Run-On
#43 Dummy Thermostatic Actuator
#48 Testing L-Jet air flow meter
#52 L-jet Throttle Body stop screw
#55 L-Jet Throttle Body Throttle Shaft
#56 Manually Operated AAV
#63 Hose Clamps for Fuel Injection
#64 Fuel Injector Replacement
#74 Throttle Linkage Info
#77 Vacuum manifold pressure sensor in L-jet
#89 Fuel Injector Hose
#113 In Tank Fuel Pump
#122 Repair VVT Bushing
#124 How to Fix Mechanical Section of VVT
#126 Lots of SPICA Info
#127 Pressurized Fuel Tank
#128 VVT Wiring Harness
#146 Spica Throttle Body Rebuild
Ignition, Starting, Charging System - Unit 05
#7 Starter Removal S4 series
#20 Oxygen Sensor Info
#99 Cap and Rotor Information
#121 Soldering Oxygen Sensor Wires
Engine Cooling System - Unit 07
#23 Thermostat Bypass Valve
#27 Engine Cooling Fans
#72 Aux Fan Temp Sensor
#94 Water Pump Replacement with PICTURES
Clutch - Unit 12
#108 Replace Clutch Pedal Pivot
#22 Clutch Master Rod Adjustment
#61 Clutch Replacement
#85 Light Weight Clutch
Gearbox - Unit 13
#54 Trans Mount
#116 Trans Mount Replacementl
#68 Transmission Oil
#69 Trans Mount Puller
#102 Transmission Rebuilding
#104 Transmission Removal
#115 Transmission Mount
#117 Fix the First Gear CRUNCH
Propellor Shaft - Unit 15
#110 Drive Shaft info
#115 Propellor (Drive) Shaft Info
We needs some links for this section! Do you have any???
Rear Axle - Unit 17
#46 Pinion Nut Socket Plans
#47 More Pinion Nut Info
#59 Limited Slip Diff vs Open Differential housing differences
#92 Rebuild Limited Slip Differential Clutch Pack
#95 Rear Wheel Bearing Info
Front Suspension - Unit 21
#28 Front Wheel Bearing Info
#35 Front End Alignment
#78 Ride Height & Springs
#97 Front Spring Install
#98 Front Suspension Rebuild with PICTURES
#111 Upper A-Arm Info
Front and Rear Brakes - Unit 22
#80 Hydraulic Bleeder Screw Specs
#96 Sticking Brake Calipers
#103 Rebuilding Brake Calipers
#107 Replacing REAR Brake Pads with PICTURES!
#144 Hand Brake Rebuild
Steering - Unit 23
#17 Replace Steering Box Seal
#34 Steering Box Adjustment
#143 Steering Box Disassembly
Rear Suspension - Unit 25
#37 Rear Shock R&R
#90 Rebuild Rear Suspension with PICTURES
Electrical System - Unit 40
#5 Headlight Relay Info
#6 Fuses and Relays Info
#11 Ignition Switch Removal
#24 Warning Buzzer Locations
#30 Fuse Box Upgrade
#32 Fuel Sender Wiring
#33 S3 Ignition Switch disassembly
#38 Install Starter Relay
#41 Make Your Instruments BRIGHTER
#45 Removal Turn Signal Indicator
#50 The Key switch goes bad for the starter
#51 S2 dash warning lights ~ lamps
#58 Fitting headlight covers onto series 3 and series 4 spiders
#79 Remove the Flywheel Sensor
#81 Headlight Replacement
#82 Lighted Ignition Switch
#112 Jaeger Gauge Test-Setup-Data
#123 How to Fix Slow Speedometer or Tachometer
Doors - Unit 65
#13 S3 Power Window Cable Adjustment
#16 Door Handles/Locks/Panels
#19 Door Limit Strap
#31 Vent Window Latches
#65 Door Latch Spring
#83 Door Lock Info
#100 Remove/Replace Vent Windows
#119 Electric Mirror Fix
Hoods - Unit 56
Internal Trimming - Unit 66
#26 Steering Wheel removal
#36 S3 Console removal
#62 Glove Box Door Straightening
#60 Series 3 dual pod center console
#66 Cowl Drain Hose
#86 Dashboard Cap
#93 Early vs. Late S2 Vent Differences
External Trimming - Unit 75
#44 Factory Convertible Top Manual
#53 Bumper Conversion Mysteries Revealed!
#66 Cowl Drain Hose
#75 Convertible Top Replacement
#125 Rubber Bumper Repair
Ventilation, Heating and A/C System - Unit 80
#49 AC Maintenance
#76 AC/Air Conditioning system wiring
DO NOT post new questions or comments here!!
If you have a question or comment about the FAQ, send me a PM and I will respond.
? RIP Tifosi - 1966-2013 ?
The FAQ is dedicated to Darren Gates = Tifosi who was so important to this forum
#9 Oil Seperator
#57 VVT O-Ring
Clutch - Unit 12
Gearbox - Unit 13
#54 Trans Mount
Rear Axle - Unit 17
Steering - Unit 23
#37 Rear Shock R&R
Doors - Unit 65
#83 Door Lock Info
Hoods - Unit 56
#66 Cowl Drain Hose
#86 Dashboard Cap
#66 Cowl Drain Hose
#49 AC Maintenance
