Fixed hood
Bob - the pretty girl in GTD's version trumps 'Giancarlo' in your version
Christof, welcome to the world of Interim Spiders, this is our 15 July '60 - 1495 10990 - with the fixed hood, with the rear portion of the top fixed to the rear deck, raising & lowering the top is so simple.
Up = seat backs forward, reach in alongside the body, grasp the bottom of the frame arm and pull, top swings up & then fasten the two clips either side, pull the frame a bit harder & it locks into place, then extend front piece forward by pulling forward with one hand and pushing upwards with the other, latch onto windscreen.............job done
Down = seat backs forward, unclip the top from the screen, move the front portion backwards to above the seats, loosen the latches on the frame and allow to drop very slightly, now loosen the two clips on the body, then allow the whole thing to settle into place behind the seats, fold in the two 'wings' on either side of the hood (with the body clips), push back on the top bar until it is snugly behind the seats..............job done.
I usually have it up or down in time to go help my Dad with his '57 hood...both of us want the top version used by Edward Fox in the day of the Jackal
The main problem with the fixed hood is that the rear window drapes over the rear deck & the buffetting from the wind damages the clear plastic,
Alfa originally supplied a soft pad to prevent this. I use a red towel folded carefully under the screen & also use a black towel to 'pad' the top bar of the hood to prevent damaging the seats - visible in the pictures, but hardly noticible even when the vehicle is parked.
The fixed hood is much easier than the early or later cars, BUT, it does spoil the pure lines of the car a bit. I don't have the original top or the original cover & drape combination which came with the fixed top cars. Andrew Watry has a very original '60 Spider Veloce with the original cover & drape combination.
Ciao
Greig
