Hello everybody,
The inside hole diameter of the knob is 2.5 '. !
Not sure what you mean by this. 2.5 in, mm, or cm all don't seem to make sense.
It does look like the knob has a rubber insert, like the original Alfa knob, so if it's the right size, you're good, and if it's a bit larger you could probably secure it with some silicone sealer.
Discussion Starter · #5 ·
I asked the seller and he told me the gear knob is for Mercedes ( although it is without Logo ); the hole diameter is 10 mm without screw - it is a push-in fitting.
