1 - 5 of 5 Posts
Like many owners, I have found the roof of my 2002 Duetto not operating. Dealer advised to hit the motor with a hammer!This worked for awhile but now totally stuffed! Not going back there, so does anyone know of somewhere to obtain a roof motor to suit. Located in Queensland Australia.
I would find a able auto electrician, who will be able to diagnose the problem.
Quote: "my 2002 Duetto". Is that what a 916 Spider is called down under ?
Erik
If the roof cover does not open, then it could be that the motor has a cracked or tooth stripped plastic cog
If so then this is what you need.....
Alfa Romeo Spider Electric Roof, Replacement Gear 95-06 on eBay (end time 01-Feb-11 20:46:04 GMT)
But check that your cog needs replacing before ordering !
I think that someone in Austalia has had a batch made - check eBay.com.au
I purchased a new roof motor and the eBay nylon gear a few years back. Replaced the broken gear, now have a spare roof motor assembly. Unfortunately, the replacement roof motor hangs a few times a year.
The roof motor is designed for a quick release when there it gets hung. To release, grab the motor assembly with both hands and provide a firm squeeze. Likely the same as hitting with a hammer. In my experience, the gear broke rather than ruined teeth. The only way to release tension was to disassemble the latch cables at the roof motor assembly.
The original advice is correct! That said, if you hear whirring noises then the other posts seem to to advise well. I recall a UK post describing replacing plastic gears with brass......not cheap but seems bullet proof if you intend to keep your car? I have had to hit mine twice............hood still fine (2.0 Spider Lusso, automatic hood)
1 - 5 of 5 Posts
