Well ,, I dont know which Guiseppe designed this nightmare, but he needs to go back to school... they must've put the clutch master cylinder on before installing engine.. Any way after 4 hours and the solution came to me at 1;00 am in a dream.... here's how to get the bottom bolt out without removing anything. You need standard length about 3" L shaped 6mm allen , 6mm ratcheting closed end wrench, 13mm open end wrench.
remove the clutch pedal pin to the master clutch cylinder,, washer and cotter,, then bungie the pedal up to the seat so itis out of the way,, then push in and up on the cylinder fork actuator , so it is up and out of the way,, now you can get the allen into the capscrew
there is no room to move the bottom nut holding the clutch master cylinder on the booster,,, so just get a bite on the nut with the 13mm oe wrench... then slide the 6mm allen onto the 6mm closed end ratcheting wrench,,, then feel the bottom allen cap screw and wiggle" the allen/ratchet assy until it engages in the 6mm capscrew,,then pull towards to you ,,holding the 13mm wrench at the same time ,, success!
only to find the master cyl was in perfekt Konditshun
