Friends, I was wondering if anyone can tell me which injector are similar to the injectors on an L-jetronic Spider. If I am not mistaken, the Milano injector are the same as the spider, but i could be wrong. Can anyone confirm it?
I need some injectors, mine seem not to work at all. Any inputs?
1966-2013
If they all seem to not work, then it's more likely you've got a driver or delivery issues rather than an injector issue. (the odds of all the injectors failing at once are pretty slim even by lottery standards, unless it's a case of the car having sat for a really long time and they are gummed up)
So what would you suggest, I check in your opinion. I even went as far as opening the drive relay case and see the drive relay activate. and it sure does.
I checked the spark plugs, and they are dry very dry... and i would assume that after so many cranks on the engine the plugs would be a little wet.
