41 - 60 of 101 Posts
@Peter,
yep, certainly makes you think. I remember being horrified at some of the prices for bits on my old Pagoda SL, though looking at how much they go for now (anything from £40k-£100k+), the spares now seem relatively cheap! And to think that when I got rid of my first one, it went for under 6K which included a full leather interior refurb (seats, panels, dashboard) and complete carpet refit in luxury top-of-the-range Axminster. The good old days, when you could find a quality upholsterer (this was ex Rolls Royce geezer) for reasonable money (I remember the whole lot cost me about £360)! Nowadays you'd be lucky to get your headrests done for that sort of money ;-( . Am just hoping Mozzafiato comes through with the seals, as it would be nice to get the space back, not to mention a useable top. Regards and happy motoring! Vin
will reach out just as soon as the sets are complete. will post pics as soon as they are ready
MOZZAFIATO,
I'm also interested in a set of gasket seals for the hardtop. I have a 1991 S4.
Also, does anyone know a supplier that sells the hardtop interior plastic pieces? I'm looking for side shields (part #60519455 or 56) and stub plane, the plastic piece that stretches across the center under the rear window (part #60519429).
Placide
64 GIULIA SS, 71 GTV, 91, 92 SPIDER
Discussion Starter #43
MOZZAFIATO,
Placide
keep you posted, coming soon!
I have an old factory hardtop I bought 18 years ago, it fits my 84 Spider, although I believe hardtops were not available for Spiders 'till '86.
The side gaskets are decaying and the J-hook covers are broken.. The clips that clip them in place are flimsy plastic, and I've read they break easily... So as was mentioned by Mozzafiato, I need these J-hook covers also.
Any one have any idea where I could find these J-hook covers, or the little gasket that sits at the bottom of the gasket that is behind the side windows?
@CLeopold.
Welcome to the elusive seal-seakers! Maybe someone should start a section solely dedicated to this "now" mythical and legendary item. Anyway, on a more serious note, the little rubber bits that are found at the bottom ends of the seal. As far as I know, these are part of the seal assembly (though someone else may be more knowledgeable than myself). The only parts that I have seen available for this "white elephant" of an item are the front top rubber and also the gasket for same. Not sure if I might have seen a rear rubber somewhere, as i've lost track of the sites i've trolled through over the past 6 yrs. Am also unsure if the hooks are available (have seen them occasionally second-hand). Same applies to the rear body retaining hooks for the top. As to the little covers. Never seen these advertised, but if you're willing to spend an hour or so in your shed (or wherever), I can't see these as being too difficult to knock up, as they are only 2 small semi-rectangular pieces which you cut out of some thin plywood or hardboard and cover them with vinyl (and a thin bit of sponge if you want them looking nicer). The only fiddly bit would be the four connecting bits on the back, though you should be able to figure a way of attaching something there to do the job (maybe get some of that putty mouldable glue -sugru? or adapt some type of metal clip and glue to the back)). If it helps, i'll be more than happy to send you pics of them and measurements in order that you can get an idea of the pattern. Good luck. Vin
Hi Tony, welcome to our desperate little gang. You need to contact Mozzafiato (at the beginning of the thread), who is the hero trying to sort out production of these sneaky and very rare seals!
Thanks, still getting the hang of this site. Belonged to the Speedster Owners group for many years. Found great advice and friends. Thanks for the direction
Hey, thanks a lot Vin, I actually have the covers for the hooks, but they are falling apart, the little plastic tabs that hold them in place are broken. Will check into the moldable glue, seem to recall there is a silly-putty like glue that can be pried off when needed.
We should form a group society to search for all these gaskets!
I want in on this as well when a set comes on the market. Find out who made the tops and you can find out the manufacturer of the sets. Who knows, maybe the molds are languishing in the back of some shop. :)
What I think will have to happen is someone will have to donate a top to have something to replicate from. A company, whoever is chosen, can then use the rubbers to make an extrusion mold with a minimum run of feet/meters. All that would be needed is about 6 inches to get a profile. The mold cost is expensive to have cast. The rubber isn't that expensive once the machine is turned on.
The caveat is that the rubber extrusion has to be of a decent durometer so that we are not replacing sets every year. If the rubber is to soft it won't seal properly and take a set. If you notice the rubber on the tops is fairly hard, but resilient so that it seals do not take a set very easily.
When a few sets are sold to recover the mold costs the costs can come down. I am sure there is enough demand to sell a lot of sets.
As to the cheap plastic covers, you can find someone to make a mold and cast some new ones. Again the mold will not be cheap. At that point, you can make some improvements over the old design that will allow them to hold up longer. Possibly a set of rubbers and new lock covers could be sold as a set because everyone will need them.
the rubber bits at the bottom are separate. There is a left and a right and also two different types according to which S4 hardtop you have (hardtop seals were updated at some point according to parts catalogue: either a C12 or a D12...(maybe Papajam knows when this adaption came in?)
so, another bit of unobtanium
this is one on german ebay (poor photo, but you get the idea)
complicated looking thing;)
Discussion Starter #54
good day fellow seal seekers,
i will be attending a production meeting regarding these seals, what a task these have become. if it wasnt for the encouragement of a lot of you in this forum we probably would have given up a few weeks ago and gone topless with our spiders.
will keep you all abreast of any revelatory information around these seals, they are still in the works and coincidentally the 2 "joints" that are being discussed above have given us the most trouble and expense. but we will prevail.
patience!
@spiderserie4;
thanks for that correction. As mine are long gone, I didn't even know what they looked like. Could you possibly advise what they're advertised as, or even a link to the said item on ebay, as I might just get these to see if they help with the water ingress problem on the hard-top.
Thanks a lot.
@spiderserie4;
Thanks a lot.
patience!
Thanks for your efforts on this!
Doug
Are you considering Metro Molded Rubber? They have been in the restoration business for a very long time for car collectors and specialize in making "unobtainium" rubber for just about anything.
@spiderserie4;
Thanks a lot.
Hi Vinnie,
there is only the one on german ebay, a right side
Ebay # 192111121232
But it is way too expensive in my mind, unless you were going to take a mold and reproduce it, then NOS is what you need!
You could keep a search out for the part nos, I suppose, that's how I find most of this stuff!
what part of Ireland you in btw, Eire or N.I?
(Dublin myself!)
Reactions: CLeopold
@spiderserie4; Thanks for that. I did look on German ebay last night, and after trolling through 20 pages of listings, eventually gave up. I'll chase up that item number just to satisfy my curiosity. BTW, am in South (republic).
Cheers!
