105/115 Series Cars Rear Sway Bar, Will Fit Spider GTV Berlina As Original Or Add To Earlier Cars; Super Duetto Etc., Comes With Rear Trailing Arm Bolts, Good Condition, SOLD
Brad is correct, Spider has longer arms (the ones that point towards the rear of the car and GTV shorter, not sure about the Berlina.I think the Spider bar has different length arms (longer) than a GTV. Or maybe it is the S1 vs S2 1750 situation. There are a few posts on ABB. I have a spare Spider rear bar or, so I am told.
I found the above information. I measured my bar (from a Spider) and it comes out approximately11" and down approximately 11-1/2". Alfa69GTV1750 is purchasing the bar for a Berlina so it appears there will not be a fitment issue.FWIW, the 1600 Nuova Super came w/ a rear sway bar from the factory,
part # 105.48.25.600.00 (14mm) that is the same as that found on 2000 Spider & Berlina (but not 2000GTV), 1750 Berlina, Spider and late 1750GTV (but not early), and the 1300 & 1600 Spiders & GT's (but not the late GT's that have their model designations end in 1.3 or 1.6 - they are the same as the 2000GTV).
