Mine are pretty dim, as well--I don't think it's a malfunction. That they're green, a color w/ a short "wavelength", as well doesn't help w/ brightness.
Also, this probably shouldn't be in the for sale forum.
There are a couple of other things you could check as well. Your Alfa is over 20 years old. After that much time the light bulbs can get a silver coating on the inside of the bulbs, which keeps the light from getting through. Also the contacts in the brightness switch can get oxidized over time. The quickest way to clean that is to move it from dim to bright several times and see if that makes a difference.
-Wayne
