I have a bearing out in the AC blower unit. It sounds like a box of rocks when I turn it on. Also, the blower assembly is right up against the passenger side speaker grill. I wouldn't mind upgrading the speakers. The speaker must have been installed by the PO with the blower out or loose.
Any tips on the AC blower assembly removal are much appreciated.
Can't help you with the full removal, but very often noise like that is something loose in the fan housing bouncing around along the blades, or an out of balance fan assembly hitting the housing. Usually a bad fan bearing will squeal. It's possible you might just be able to open up the covers and sort it out.
I've done it leaving the evap in the car. You will have to pull the glove box out and have a lot of patients.
