Spica cams do not work well with carbs. The standard European cams 105480320001 are much better. The factory setting for these is 99.5 degree lobe senters.
The US '75 Spiders have timing marks at 114 degrees. If you simply re-time your cams to 102 degrees you should see an improvement.
Ed Prytherch
79 Spider
2 x 88 Milano Verde's
Ed Prytherch
79 Spider
