1 - 14 of 14 Posts
I have a few Spica gaskets and others. A few I don't recognize, anyone know these? Specifically, the top left 2 in 1st photo, zoomed in 2nd photo.
1626108
1626109
Push hard and live
Are you seeking ID help, and/or to sell? If the latter, I’m driving two Spica cars plus about to rebuild a Monty engine, so don’t mind having a stock of spares.
There are only three Spica related gaskets shown:
1. Spica pump gasket to engine block. (works good for block off plate too)
2. Idle air tower on top of Spica manifold.
3. Idle air blocks on 1750 Spica air box (two square black rubber gaskets)
Anthony, I am not sure about #2 on your list. What one is that in my photos? You may be able to see I have string and tags on the 4 gaskets that are Spica specific. I have 2 "idle equalizer"(2 square black rubber) 1 pump or block off plate gasket, and the cam cover vent gasket. I can provide the Alfa part #s for those 3 types. It is the other two I am not sure of in the 2nd photo.
Don, I am looking to sell all the gaskets/parts that are Spica specific or parts that don't fit my Euro S2 1750 GTV.
Push hard and live
Thanks Brad.
Sounds like only a couple of known Spica parts, so I’ll pass. I didn’t look closely first time around.
vintagemilano, You are right about that gasket. So 4 Spica gaskets and 1 is still a mystery. The bottom small one in the 2nd photo.
The large one in the second photo looks to be the mechanical fuel pump housing gasket. The small gasket sure looks like the idle tower gasket.
Discussion Starter #13
Not for 1969 Spica, this is for 1971 and on I was told.
Another Spica specific part. The Bosch relay 0 332 005 011 in the 2nd photo. Alfa # 105.71.65.092.00 emergency flasher for S1, S2 USA 1750 GTV, likely Spider, possibly 2000 as well.
1626832
1626833
1626836
1 - 14 of 14 Posts
