I have a '74 Spider with Spica FI. The FI pump needs rebuild. Who has experience with Ingram Enterprises, Gary Martin from So Dakota (advertising in Hemmings), or other rebuild sources?? I need some guidance concerning the positive / negative results on the rebuilds on their SPICA pump, and who I should engage to rebuild mine.
Thanks for your comments.
I'm sure you'll get this repeated several times, but you can't go wrong with Wes Ingram and Herb Sanborn at Ingram Enterprises. My pump failed shortly after it was rebuilt - very rare, but it does happen - and Wes took care of the problem promptly and on his own dime.I have a '74 Spider with Spica FI. The FI pump needs rebuild. Who has experience with Ingram Enterprises, Gary Martin from So Dakota (advertising in Hemmings), or other rebuild sources?? I need some guidance concerning the positive / negative results on the rebuilds on their SPICA pump, and who I should engage to rebuild mine.
If Wes or Dan decide to drop their Spica biz, we Spica owners are in some very deep kimchee.
Yes, you're correct that the engine will not run at all.
I forgot to mention that, when I recently acquired the car, there were 20+ Lodge spark plugs in the trunk. The prior owner indicate it ran very rich and fouled the plugs constantly. This seems consistent with a FI pump on its last legs.
I'll have the injectors cleaned also.
I don't know if I'd condemn the pump completely. It's possible a bad T/A or some other problem would cause the rich running. An overly rich mixture can cause gas in the oil just as a worn out pump will.Yes, you're correct that the engine will not run at all.
-Jason
I'm not at all familiar with Gary Martin here in my hometown, Rapid City, SD. I looked up his ad in Hemmings and it seems he does carburetor rebuilds, but no mention of Spica injection pumps. I'd be very surprised if he does Spica pumps, given the very specialized tools, test bench, experience, and replacement parts necessary to service them. Since very very few new parts are being produced for the pumps, rebuilding a Spica pump is a black science of small production (read expensive) of special parts, as well as re-combining used parts as in the case of plungers and barrels.
There are only two rebuilders of Spica injection pumps that I know of . . Wes Ingram of Ingram Enterprises, Burlington, WA and Dan Wells at Foreign Auto Menders in San Diego, CA. If Wes or Dan decide to drop their Spica biz, we Spica owners are in some very deep kimchee.
Both have excellent reputations, but I've only personally dealt with Wes Ingram whose reputation is iconic in the Alfa community.
Contact info for both companies is located here . . . http://www.alfabb.com/bb/forums/anything-about-alfa-romeos-alfabb-com/4361-supplier-list.html
BTW, what symptoms exactly is your injection pump exhibiting that makes you think it needs a rebuild? Many times mechanics that have little knowledge of the system will advise owners that "it needs a rebuild" when all it might need is a new TA, microswitch, or merely a accurate tuneup.
Interesting....where does one find Gary Martin?..just had my 1980 Spica rebuilt by Gary Martin. .... He has a test bench and also puts the system on his test Alfa and drives it for a while...
