I just purchased a '73 Spider with the original SPICA fuel system. After the first few days of driving it started leaking fuel at the main filter o ring. I didn't see how the seal was installed when I removed it. I bought a new filter and seal but now I'm not sure where the seal goes. I can't get it to stay in what appears to be an o ring grove on the underside of the top half that has the fuel fittings (per this sites recommendation, I removed the whole assembly - great tip). The seal will fit around the top portion of the fuel canister.
Can someone please advise if the o ring has to be forced into the grove on the side under the fuel fittings or does it go around the top of the fuel canister?
Also, do I need to fill the canister with fuel before reinstalling it to make sure the pump doesn't run dry when I start it back up?
Thanks for helping a new guy. I've spent hours searching for an answer and found a thread from June/July 2005 with the same question but it wasn't answered. I've attempted to add a photograph from that thread (Rassilon, 7-22-05, #12 permalink in the injection section - the picture is at link:http://www.alfabb.com/bb/forums/carburetors-fuel-injection/12906-fuel-leak.html)
This site has been a great help in learning about this interesting automobile.
Thanks for helping a rookie.
