Spica intake $50 plus shipping (w/ injectors) Also available, airfilter box, door handles inside & out, rear hatch and hood, front grille & rear lights. Pedal box w/ brake booster, driveshaft & dedion.
Will it fit? Yes
Is it correct? No
The 1969 model year was unique in that the idle air system used 2 idle equalizers mounted to the airbox. The above pictured manifold is a 1971-1979 with a single air distributor (or air tower) mounted on the manifold.
Two solutions; one would be to just remove the air tower and hook up the 4 idle air hoses to the existing idle equalizers. The other solution, which would be required to hook up the idle air system correctly if you do not have a 1969 airbox, would be to install a 71-79 airbox.
Thank you for the precisions PAPAJAM !
it is for a friend who has bought a 1750 duetto and want it to be in his original state.
His duetto had been converted to carbs .
I will send you foto soon.
Bye
Discussion Starter · #5 · (Edited)
Engine for sale
>>>GONE>>>2L spica & transaxle w/ calipers and many other used spares available.
Will it fit an '85 spider? we are considering a Weber conversion ans suspect this is the correct intake.
thanks,
If correct we will take it
