1 - 17 of 17 Posts
Can anyone tell me where and how the hand throttle cable hooks up in a Spica equipped car? My 76 Spider has a non operative cable that just runs into the engine compartment and I don't have a clue how it could have been hooked up.
Discussion Starter · #4 ·
That's the obvious spot, but this cable runs 3-4 feet past that point and has a diamond shaped flange on the end with two fasteners that looks a lot like the T.A. fitting on the Spica.....? Is this just some PO misadventure?
Yes, hand throttle..................torque DD.
That's a Shankle Sure-Start, which is a mechanical replacement for the TA. I have had one on my '74 Spider for many, many years. Works perfectly, and it allows you to tune the fuel injection as if the engine is at normal operating temp, even when it's cold. There are nay-sayers out there, but I first used one on the early 80's, and wouldn't use anything else.
:confused::confused::confused:Hand throttle, torque DD:confused::confused::confused: Don't use words, use pictures to describe what you are talking about. Saying hand throttle reminds me of hand controls, none of which I see in the engine bay...
I agree with BSN05 that the Shankle Sure Start is an attractive alternative to a TA. I've had one on my '69 Spider for 18 years. In my installation the lever for the Sure Start is mounted next to the hand-throttle lever, although I am told that some installations employ the hand-throttle lever for the Sure Start, thus eliminating the hand throttle.
Here are the instructions for installing a Shankle Sure Start. It's not a hand trottle. It's used to start the car if there is no thermostatic actuator.
http://www.alfabb.com/bb/forums/showthread.php?t=19183&highlight=sure+start
The hand trottle is a solid wire that attaches to the accelerator linkage on the driver's side of the car.
Here's a picture of the '74 mounting. Note that there is a special bracket that attaches to the brake booster. If yours is missing one can be easily fabricated from stock. Also note that the cable lock on Osso's picture is correct. I added the metal grommet to keep the cable square in the center of the large throttle linkage ring. Why Alfa did it the way they did, I have no idea.
The hand throttle is a solid wire
Simular to or just like those found in a manual choke cable kit, or some Dodge hood releases then I take it. (I seem to recall the old late 70's Power Wagons having that style for some reason......)
Just thought I'd toss that out there in case someone is looking for a proper type cable to repair thiers.
I use the hand throttle on my 74 Spider much as one might use cruise contol in a more modern vehicle. That way, when I'm cruising at 135 MPH, I can pay more attention to the front bumpers of vehicles I have recently passed, just in case I have signed my name backwards on their bumper in reverse script. :rolleyes:
1 - 17 of 17 Posts
