I need a source for a new crankshaft oil seal for my Spica pump T255/1.
Also, looking for replacement gaskets for pump to base and base to block.
Thanks, Paul
Paul,
Have you removed the old seal?. Bearings are supposed to be universal / generic sizes, so seals may be the same and your old seal may have an ID number.
I have an old SPICA pump shell, and may be able to remove the seal to see if there is an ID number. Or, Wes Ingram may be able to help with seal and gaskets.
Thanks, Paul
George,
I have not removed the pulley, but I can make out some ID nos. I did not know they are universal and assumed the ID might be out of date after almost 40 years. I will try to cross reference once I get a better look at it. I considered measuring after removing the seal but don't want to count on values taken from a worn/deformed seal.
Thanks for offering and advice.
Paul
