1 - 15 of 15 Posts
Looking for something to push onto the Spica airbox lip under the lid. The stock rubber is some small u-channel rubber. There has to be something similar out there easy to find, no?
As a result of your post, I realized mine is missing!!
I'll monkey around and see what I can come up with.
Check out Steele Rubber Products or Mcmaster Carr Both have u shaped rubber trim in bulk
Thanks, Rick
1978 Spider 1984 Spider
generic edge trim should work. like those door edge guards. I'm planning to try that since mine is old and brittle. I suspect a hair dryer or heat gun might be needed to coax it thru the bends.
My measurements of the existing rubber show roughly the same outside measurements. The airbox wall is about 1 mm, though. I wonder if this would be loose, therefore. Probably not looser than the old decrepit piece there still remains and it's held in place by the lid anyway. So, I'm tempted to buy this.
I wonder if you could use some vacuum hose? just carefully split it long ways with a utility knife? it's usually very pliable and should mold around the curves easily.
If it's a tad loose.....use a little bit of some Black RTV and let it fully cure before installing the cover.
Well it arrived. Looks to be a pretty good match and is very soft. The old one on the right is hard an brittle.
got some scrap door edge guard from a friend...was about the same size as the stock seal but there are probably a couple different sizes out there so maybe I lucked out...fit right on and around all the curves just fine. had both ends meet at the one "corner" on the air box.
As @0die mentioned, I too used door edge guards from Autozone on mine. It's not exactly a soft rubber, but provided a more than adequate seal on my spica air box. I've been using it for over two years and it seems to work pretty well.
1 - 15 of 15 Posts
