1 - 5 of 5 Posts
The speedometer stopped working when I took the car out from winter storage.
i lifted the aft axle up, I disconnected the speedometerwire from the electro unit located close to the clutch cylinder. Started up the car to check if the wire was rotating. No rotation I when running the car full speed in second ****.
sounds simple enough in your case
... if cable is not turning it must be the cable
can you pull out the inner cable? normally if it is broke, you can
OK
check the connection where it screws into the gearbox...maybe that has come loose....or the "square" end that fits into the gearbox speedo gearing has rounded off....undo it and check.
1 - 5 of 5 Posts
