I need the following:
- a 2000 GTV speedometer graduated in kilometers; has to be working, face and pointer could have cosmetic damages
- a 6 teeth speedo drive pinion from a car with a 4.10 rear axle ratio (typically Euro spec 1750 or 2000). This is the brass part that is fixed to the tail of the transmission with two 6mm bolts and onto which the speedo cable is threaded
