1 - 1 of 1 Posts
I cracked the sump on my q over xmas while I was away camping. Anyway I put the car on the hoist at work and swapped it for another one we had there from a gtv6 engine conversion. Being a mechanic I don't often get around to fixing my own car so while I was there I thought I would try another fix on the speedo sensor.
I carefully drilled a small hole in the side of the unit and cleaned it out with contact cleaner. So far so good. Seeing as this is a common fault I hope this might help a few others.
1 - 1 of 1 Posts
