1 - 2 of 2 Posts
What is the expected life for the Golden Lodge Spark Plugs? I have done about 10000 kilometers with mine. They seem to be OK... If I switch to NGK what differences are there (if any) between NGK and Golden Lodge, and finally which are the correct NGK ones for a standard 1300 engine with electronic ignition?
NGK B7ES should be the correct ones, avoid the "BP"-version as the "nose" is longer which can cause problems in some applications.
1 - 2 of 2 Posts
