1 - 14 of 14 Posts
My January 1959 Spider has, or had, boots like the one in this photo of my brake light switch on the terminals for a number of electrical components, such as the ignition coil and distributor (low tension) and the generator. The boots have been crumbling apart. I have not found replacements from the usual sources. I suspect that they might be same as used on AH 100s and MGAs, but no luck at the sources for spares for those cars either. Does anyone know of a source?
Thank you, Alex. I am afraid that I gave up my search too easily, but I knew that someone here would know where to look!
P.S.
Tom or anyone else, could you measure up the remaining rubber boot you have on your car to compare with the ones from the vendors Alex pointed out?
Dennis
Small on coil and water and oil senders.
larger on brake light switch and starter solenoid.
I imagine there are others but I haven't found them.
Ciao,
Bill Gillham
Jefferson, OR
Thanks Bill, but as I didn´t find one single rubber terminal cover left on neither of my cars (101 1600) and thus nothing to compare with, may I ask you what would your standard order be when ordering a complete set for one car with these guys (AES)?
If possible with the article numbers?
Dennis
Hard to tell from the pictures. I guess #1 and #3.
Use part number 070801 for the small ones
Use #070805 for the large one on the brake switch and the starter if you have the stock size battery cable.
Use #070806 if your battery cable is larger than 10 mm
Ciao,
Bill Gillham
Jefferson Oregon
1 - 14 of 14 Posts
