I've never taken as much precautions to lift a car ! Same thing for replacing U-joint on driveshafts, I used to remove old joints with a big hammer and large pliers. Usually I use the hammer to remove tension on the new joint installed too… I'm learning to be easy on things with this project !
Those wheels won't be on the car when finished. I have Serpent AutoSport wheels for that project but I will put the new wheels only after the car has been painted. Just in case :)
As much as I avoid reading posts with subject lines that provide a limited preview of coming attractions, I'm glad I overcame my iron willpower and peeked at yours!
Lovely front suspension, and if the lower engine sump and crash guard are any indication, the rest of your under-hood equipment must be equally attractive.
And while that beefy jack was just for picture taking, I'm sure you always use proper stands!
Nice work!
