1 - 5 of 5 Posts
Moderator
See my .xls file for more info not complete but hope it is helpful
CAR MODEL ENG GROUP CODE NAME AR P/N MFG MFG P/N
04 S electronic fuel injection
164 12V 04 S11 motronic control unit 60543462 BOSCH 0261200117
164 S 12v 04 S11 motronic control unit 60547306 BOSCH 0261200130
164 12V 04 S12a fuel pump relay 60805422 BOSCH 0332014113
164 12V 04 S12b motronic relay w/ diode 60807340 BOSCH 0332014112
164 12V 04 S29 idle adjustment actuator 60813370 BOSCH 0280140516
164 12V 04 S3 fuel injector 60813371 BOSCH 0280150702
164 12V 04 S31 rpm/timing sensor 60560715 BOSCH 0261210047
164 12V 04 S35 lambda O2 sensor 60808457 BOSCH 0258003061
164 12V 04 S5 air flow meter 60513206 BOSCH 0280202201
164 S 12V 04 S5 air flow meter 60550042 BOSCH 0280203035
24v 04 S5 air flow meter 94-95Q/LS BOSCH 0280203026 or 0986208042
164 12V 04 S6 min/max throttle switch 60512672 BOSCH 0280120300
24v 04 S6 min/max throttle switch BOSCH 0280122001
164 12V 04 S7 coolant temp sensor 60800167 BOSCH 0280130026
164 12V 04 S7 coolant temp sensor 5972332 BOSCH 0280130023
164 12V 04 pressure regulator 60611308 BOSCH
05 A starting/charging
164 12V 05 A1 battery type 31
164 12V 05 A11 starter 60512847 BOSCH
164 12V 05 A2 alternator 60513888 BOSCH 0120468023
164 12V 05 A5 distributor 60598664 BOSCH
164 12V 05 A5a distributor cap 60513050 BOSCH 01235522388
164 12V 05 A5b rotor 60513052 BOSCH 02885140156
164 12V 05 A5c wire set BOSCH
164 12V 05 A8 ignition coil 60513069 BOSCH 0221122344
24v 05 A8 coil pack 24v BOSCH 0221504456
164 80 Q blower fan motor 60569926 BOSCH 0130111008
164 80
164 12v 04 P18 fuel pump 60572050 bosch
164 12v 04 P18 fuel pump 60805158 bosch 0580464990
164 04 fuel pump Q4 bosch 0580453980
Thanks Steve - this is a great idea, especially for those of us with access to a Bosch specialist locally, but not ready access to Alfa Romeo parts!
In the Excel spreadsheet which I quickly downloaded/saved, I notice you have two coolant temperature sensors. One has a quantity of six, while the other has a quantity of one (I note the fuel injectors have a quantity of one also). Presumably neither of these is that troublesome gauge/warning light sender? I still plan to remove mine and 'bake' it several times, testing for continuity in the process. Then again, that random bright red light does add some character to the car, and passengers love it.
Cheers,
-Alex
Moderator
The Qty column was what I had available when I did spreadsheet in my stash mostly used parts. I haven't kept that inventory level current.
Gauge sender is not a Bosch unit and I don't think I had it listed on spreadsheet even with only Alfa number.
1 - 5 of 5 Posts
