Hi
I need help from wife when I want to put soft top on, because I need someone to push down on top so that I can clamp inside
Is there any adjustement that can be made, so that I can do all by myself
Is it new ? It may just be a little tight and will stretch with time. I find one side of mine is a little more difficult than the other - I normally do the easy side that makes the more difficult side easier.
1966-2013
Also make sure that the rubber seal on the front edge that seals against the top of the windshield is not rolled under so it lays on the lip thingy up there.
If it does get rolled, it'll make the latches really difficult to close.
To give an idea, the seal should be visible after the top is up and it should cover the screws at the ends on top of the ends of the trim piece when looking at if from the front outside. (ideally the rubber bit will be flush with the top outside edge of the windshield trim all the way across)
Top is not new and I was able to snapped it closed before
I will leave in sunshine and see if it stretch is out and is easier to close
