1 - 5 of 5 Posts
1966-2013
Wind faster :D
Prolly a good clean and lube of the motor, cable and pullies, mabe an adjustment in the little thingies that guide the window in the chance that they are causing some bind, and make sure your getting full voltage to the motor.
I opened up the passenger-side door of my '88 Quad to check the window motor, as it was getting slower and slower.
After merely re-aligning the tracks the window is speedy and much quieter.
I had a problem with my GTV6 Power windows....should be called electrically assisted windows.........anyway I replaced the rubbers and cleaned everything and still they were slow. I eventually took the car in to my Alfa guy who found the motor was not getting a full 12 volts due to old contacts. A good clean of the wires and contacts fixed everyhing.
1 - 5 of 5 Posts
